Activity Forums Media 100 Exporting AE renders to import as 16×9
  • Exporting AE renders to import as 16×9
    Posted by Bobby Mosaedi on April 27, 2006 at 1:59 am
    What render settings do i need or import settings in m100i to get media100 to recognize my imports as 16×9? this is really frustrating because it will only interpret them as 4×3.
    After Effects:
    Composition Settings:
    NTSC D1 720×486
    Pixel aspect ratio: 1.2 NTSC/DV widescreen
    Render Settings:
    Field dominance: Lower
    Output module:
    Media 100 NTSC 720, medium quality
    Media 100i hardware settings :
    720×486, 16×9 , 48,000 audio
    what else do i need to do?
    Kieran Matthew replied 20 years, 4 months ago 3 Members · 3 Replies
  • Floh Peters
    April 27, 2006 at 6:25 am
    [Bobby Mosaedi] “what else do i need to do?”
    In the “Import” dialog box, set Aspect ratio to 16:9. Or select your clip in your Bin and use the Media->Change Media Attributes
  • Bobby Mosaedi
    April 28, 2006 at 10:24 pm
    there is no way to change your aspect in the bin. I tried changin media attributes and the only thing it lets me change is my input setup, reel name and clip name. There has to be a way. Does nobody else create AE renders for 16×9 timelines?
  • Kieran Matthew
    April 29, 2006 at 4:22 pm
    Hi Bobby,
    When you import the clip into media100, rather than drag it into the bin, use the import option from the menu. From here you can set the aspect ratio of the incoming clip in the drop down at the bottom. Although it defaults to “honor file’s aspect”, setting it to “Use 16:9 aspect ratio” will have the desired effect.
