Activity Forums Adobe After Effects exporting adjustment layers as rgb+alpha layers
  • exporting adjustment layers as rgb+alpha layers
    Posted by Matty Stevens on December 12, 2007 at 5:54 am
    is it at all possible to render out adjustment layers from after effects on like quicktime png compressed rgb+alpha channel? purpose… for a layer over a premiere files. or is this pointless?
    Curious Turtle replied 18 years, 8 months ago 2 Members · 1 Reply
  • Curious Turtle
    December 12, 2007 at 7:39 am
    Adjustment layers don’t really work like that. They adjust other layers, so rendering them out solely would be, as you say, pointless.
    If it’s an effect you want, you can either try to find an equivalent effect in Premiere. Or use the communication between the two apps to cut out the render time in between. You can bring After Effects comps into Premiere now, can’t you?
    Good luck with your project,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
