Exporting a Video Clip for Powerpoint Presentation on a PC
I’m working in Final Cut Pro 7.03.
I have a clip that less than 2 minutes that I need to export to play in a Powerpoint presentation on a PC.
The sequence is set as – Apple Pro Res 422
I understand WMV might be the right format but I can’t find this setting in any of my compressing software – I have Compressor and MPEG Streamclip.What format do you recommend I use and what step should I take to create it?
Thank you for your help!!
Jocelyn
