Exporting A TGA Image stream (Lossless) from Final Cut Pro 7 for a VFX work
HI All,
Iam quite stuck, i have spoken to numerous VFX artists to try and help me fix some elements with my film, however i cannot fir the life of me figure out how to correctly export a lossless Image stream.
i dont know too much about the professional workflows for exporting video but i know that what i have been trying to export looks to me to be poor quality.
Here are the settings Iam working with, I believe I encoded the clips from the camera to Apple Prores 422 (HQ) for editing but would need to double check.
Camera: Cannon 5D mrk ii
framerate: 25 fpsI would like to know step by step how i can correctly export a high quality image stream or any other workaround to gt my footage / clips to a VFX artist to work on some special effects.
See below an image i have taken on the left is the last frame of my TGA image export, it is to dark and there is distinct loss of detail. the image on the right is a lot better the last image from my Quicktime Apple Pro Res 422 (HQ) 1920 x 1080.
im wondering why this loss happens when i export using quicktime conversion for image sequence.
Thanks in advance for any help you may have to solve this problem.
K
