Activity › Forums › Adobe Premiere Pro › Exporting a targa sequence with no alpha channel
  • Exporting a targa sequence with no alpha channel
    Posted by John Phillips on October 10, 2013 at 3:28 am
    Hi all,
    The production switcher I’m using takes in animations as Targa sequences. If the animation has a targa it takes double the amount of memory to run the animation and is very slow to load so I’ve taken the sequences I’m using, rebuilt them in premiere with a chromakey hole instead of a targa sequence but I cannot seem to find a way to export the new sequence with no alpha channel. Does anyone know how to turn off the Alpha when exporting? It is an option in Photoshop with targa files, I’m not sure why it isn’t or is so hard to find in premiere if it is there.
    Thanks.
    John Phillips replied 12 years, 11 months ago 3 Members · 4 Replies
  • Ann Bens
    October 10, 2013 at 9:18 am
    Put a black video on track 1.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Walter Soyka
    October 10, 2013 at 2:37 pm
    [John Phillips] “Does anyone know how to turn off the Alpha when exporting? It is an option in Photoshop with targa files, I’m not sure why it isn’t or is so hard to find in premiere if it is there. “
    I’m not sure that Premiere or Media Encoder offer that control.
    After Effects does: you could Dynamic Link your sequence into Ae, then render to a Targa sequence from there. Be sure to choose “24 bits/pixel” in the Format Options within the Ae output module for RGB only.
    Walter Soyka
  • John Phillips
    October 10, 2013 at 3:27 pm
    Nope. Didn’t work. Premiere just generates a full-screen alpha channel.
  • John Phillips
    October 10, 2013 at 3:28 pm
    OK. I’ll try it. I don’t know AE very well at all so hopefully the export from AE is a simple process.
