Activity Forums Apple Motion Exporting a smaller file for previewing?
  • Exporting a smaller file for previewing?
    Posted by Mcluda on May 11, 2006 at 8:31 am
    Hi, I have made an animation about a minute long, but the client is overseas and it makes more sense to make a smaller version of the animation to put online for them to view. Everytime I try and export a smaller file (ie: smaller physical dimensions and reduced quality) it STILL comes out the same size (240MB) as the original. The dimensions have been reduced to a smaller window size in the export and its fine to look at, but the memory size is just not budging.
    Any help is greatly recieved.
    Chris M
    Doyle Rockwell replied 20 years, 4 months ago 4 Members · 3 Replies
  • Chris Figat
    May 11, 2006 at 4:11 pm
    Easiest way is probably just take the original file and run it through QT pro and resize/recompress it there. not sure why resizing in motion isn’t changing the filesize though.
    chris
    i’m not random i’m tangent oriented
  • Luke David
    May 11, 2006 at 4:56 pm
    You might want to try sending it back to (or importing it into) FCP and then trying Quicktime conversion which offers good control of the image and file size.
  • Doyle Rockwell
    May 11, 2006 at 6:04 pm
    Heya,
    If you have Final Cut Studio/Suite, you can export from Motion via Compressor, which is designed to give you control over size and format. You can find it unde the File menu in Motion.
