Activity Forums Apple Final Cut Pro Legacy Exporting a Non – Stereo Mixdown DV file
  • Exporting a Non – Stereo Mixdown DV file
    Posted by Sciphiyem on May 17, 2007 at 7:35 pm
    Is this Possible? I need to export a DV Sequence (i’ve set the audio outputs to 6 Dual Mono) so that it has 6 mono tracks rather than a stereo mixdown? can i do this in one file? or do i need to export separate aiff’s?
    Frank
    Debe replied 19 years, 3 months ago 2 Members · 1 Reply
  • Debe
    May 19, 2007 at 12:41 pm
    What’s your goal?
    If you’re sending to an audio facility, three separate AIFFs if usually the way to go, if they can’t take an OMF. If they can take an OMF, then that’s what you want to export, plus a self-contained, usually low res, small frame size QT file of the timeline that they can use for reference. (that is usuually requested for either the AIFF or OMF method)
    If it’s something else, please tell us what you’re doing, or why you need to get these files out separately. It may help us hel you figure out a workflow for you that’s efficient.
    debe
