Activity Forums Adobe Premiere Pro Exporting a MP4 file In Premiere cs5
  • Exporting a MP4 file In Premiere cs5
    Posted by Alvin Lowery on April 3, 2014 at 8:06 pm
    I have an original Mp4 file I need to edit the first three mins. out It is only 126MB. Import into Premiere CS5 and export an MP4 file and the size increase to 1595 MB. I Used a DV Project setting since the original file is only 640×480. I used an you tube SD preset export setting.
    Alvin Lowery replied 12 years, 1 month ago 2 Members · 2 Replies
  • Vince Becquiot
    April 3, 2014 at 9:55 pm
    Hi Alvin,
    First, setup a custom sequence, 640×480, square pixels (1.0). For your export settings, use H.264 (not Quicktime), 640×480, square pixel, set a bit rate around 6Mb/s, that should get you pretty close.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Alvin Lowery
    April 4, 2014 at 6:33 pm
