Activity Forums Adobe Premiere Pro Exporting a .mov file from Premiere Pro
  • Exporting a .mov file from Premiere Pro
    Posted by Noriko Cooper on May 30, 2015 at 3:55 pm
    Please help.
    I am new to video editing and Adobe Premiere. I am trying to do what seems like a simple task of exporting a file into a QuickTime format with certain parameters. None of the my editor friends can seem to help me. They all use Avid or Final Cut.
    This is the output I need for the digital video:
    Format\ Dimensions\ Frame Rate \ Video Codec
    HD1080p\ 1920×1080\ 29.97 or 30\ Photo – JPEG
    The footage was shot at 29.97 fps. This is how I imported the file.
    I also tried importing the info as a DSLR 1080p 30 and I get the same results as the following two images.
    When I use the QuickTime preset you will see how the summary output changes the fps from 29.97 to 23.98. I can’t figure out how to keep it at the 29.97 output.
    I also tried clicking the Match Sequence Settings. The output is correct but it changes the format to mpeg and I need it to be .mov.
    I would greatly appreciate your help. Thank you.
    Noriko Cooper replied 11 years, 3 months ago 2 Members · 2 Replies
  • Richard Herd
    June 2, 2015 at 10:03 pm
    From the beginning…
    1. Import the footage by using the Media Browser, navigate to the footage and drag it into the project pane.
    2. Right click a piece of footage and choose “New Sequence from Clip”
    3. Edit.
    4. Now that you’re done editing, File > Export > Media, and that will open a new dialogue box. In that box, choose the output settings you want.
    Note if you want to work in a more FCP7 or Avid style workflow, then you start in an application called Prelude.
  • Noriko Cooper
    June 3, 2015 at 2:59 am
    I got my questioned answered. Thanks for the help.
