Exporting a long sequence to burn to DVD (FCP7/ Compressor/DVDsp)
Hi There
Ok a bit of background:
I shot a wedding on my Canon 60D DSLR, it shot h264 (as they all do) and so i transcoded to prores 422 to edit with in FCP7.
The problem :
The whole day turned into about 4 hours of footage which i have broken up into single videos. The problem is that the Wedding ceremony itself is almost 2.5 hours long.
I need this to go to a DVD. I have burnt the other videos to a single layer disc using DVDsp (through compressor at H264 6.75MBPS) but this will obviously need to go to a dual layer disc.
I tried “sending to compressor” (compressor 3 btw) then exporting it using the following preset:
Description: For HD DVD. Fits up to 90 minutes of video with Dolby Digital audio at 192 Kbps on a DVD-5
File Extension: mov
Frame sync rate: 2 seconds
Video Encoder
Format: QT
Width and Height: Automatic
Pixel aspect ratio: default
Crop: None
Frame rate: (100% of source)
Frame Controls: Automatic
Codec Type: H.264
Multi-pass: On, frame reorder: On
Pixel depth: 32
Spatial quality: 50
Min. Spatial quality: 50
Temporal quality: 50
Min. temporal quality: 50
Data rate: 6.75 (Mbps)
Audio Encoder
16-bit Integer (Big Endian), Stereo (L R), 48.000 kHzIt took three days and unfortunately (and you can laugh here) when I went back to double check the video i noticed a mistake – sound went out of sync without me noticing as ive been pulling all nighters to finish this) so im back to exporting it again.
in the meantime ive had to change machines…Now I am not using the work computers anymore so I have FCP 7 , but i now have compressor 4. These apps dont talk to each other.
Right now im trying to export it straight from FCP 7 with the settings : H264, restrict to 7000kbps (trying to mimic the compressor 3 settings) but i can already tell im not going to get what i want (just a bad feeling it cant be that easy!)
Can someone tell me how best to export this 2.5 hour long video and get it onto a dvd (dual or otherwise) so that I can put this project to bed?
and did i use the right settings with the other videos? they dont look as good as they could to me….
I am well used to using FCP 7 etc but this is my first time needing to burn DSLR footage to DVD – i usually just work on online videos. And its driving me insane.
I have fcp 7 and compressor 3 on my home computer but for some reason compressor keeps asking for a serial number as its saying my one is invalid and ive tried fixing it by putting the proapps files into the application support folder etc etc so ive given up on that being my fix…
thanks
