Activity › Forums › Apple Final Cut Pro Legacy › exporting a keyed pic to DVD studio Pro from Final Cut
  • exporting a keyed pic to DVD studio Pro from Final Cut
    Posted by Jason Noto on June 2, 2006 at 7:23 pm
    Hello,
    I am trying to export a pic with a keyed out background to DVD Studio Pro. Is this possible, so far, I’ve tried the quicktime converstion to still image, but when I import the pic into DVD studio pro there is a black background. I am going to be putting a brushstroke shape underneath my text pic in DVD studio pro, that’s why I need the text keyed from the background.
    Thanks. I appreciate any insight and info you are able to share
    Jason
    Bret Williams replied 20 years, 3 months ago 4 Members · 3 Replies
  • Rennie Klymyk
    June 2, 2006 at 11:55 pm
    Maybe try to make a still frame in the viewer first and de-interlace. then do the qt to still.
    “everything is broken”
  • Todd Reid
    June 3, 2006 at 12:14 am
    What format are you exporting to?
    if you select PNG during your export, it should maintain any transparencies.
    A stop-over at photoshop would do the trick too.
  • Bret Williams
    June 3, 2006 at 3:49 am
    Track 1 has to be turned off or else fcp will put black into the transparency just like it does for video.
