Activity › Forums › Apple Final Cut Pro Legacy › Exporting a great wmv file
Posted by Greg Ball on September 26, 2011 at 4:53 pmI have a video shot on a Sony EX1. It’s 4 minutes long. Exported it as a uncompressed QT. I made a larger WMV file that looks great! 640X360. But when I try to make a smaller version 320 X 180 it looks like garbage.
I’ve tried exporting direct from FCP using flip 4 mac, and also through MPEG stream clip. Still it looks like garbage. I also tried Squeeze. No better.
The timeline is progressive. Do I need to deinterlace the footage? What bit rates should I use? Any other advice? Thanks.
Chris Borjis replied 14 years, 12 months ago 6 Members · 9 Replies -
Rafael Amador
September 26, 2011 at 5:01 pmTry Compressor with the Frame Control ON.
Everything to be played on a computer needs to be de-interlaced.
QT do not supports Interlaced stuff smaller than 640×480 (or so).
rafael -
Brent Hannigan
September 26, 2011 at 6:25 pmI sometimes export using the iPhone setting in QT7 then take that file and export a wmv from that. Just my method for nice looking wmv.
Final Cut Pro and Avid Editor
http://www.brenthannigan.com -
Bill Hall
September 26, 2011 at 7:57 pmFirst try send to compressor rather than using the quicktime file. Compressor will then use the native files for compression giving you better quality.
What is the bit rate of the smaller frame size .wmv? You may need to pump it up if you have a bunch of quick cuts or camera moves in your video. Really though at that frame size even 500 kbps should look pretty good. What wmv codec are you using? Try using WMV 9 advanced, it has some extra tricks in the bag to help with smaller video.
Try some of these things out and we can go from there.
Bob Tompkins
September 27, 2011 at 1:11 pmI do all of my HD (I am assuming you are starting in HD) to WMV using the following settings…Export using QT conversion>format windows media>options two pass VBR>bit rate 1500 kbits/sec> size whatever you want just 16×9 or 4×3>advanced input interlaced> output must be progressive
I have had very good luck with this formula which someone here gave me. I have Flip4Mac HD or whichever is the most expensive.
Greg Ball
September 27, 2011 at 6:03 pmThanks everyone I’ll give your suggestions a try and get back to you.
Chris Borjis
September 28, 2011 at 12:18 amdoing it through compressor is not going to help as the resize options are not there like they are when you do an .mov
what I do is export from fcp as quicktime conversion and set the size to 640×360 prores codec.
take that into compressor and use a windows media preset (have flip4mac here too)
if it still looks ugly, make it closer to the size it’s supposed to be when you do the export quicktime conversion from fcp.
the windows media export has no function for ensuring the resizing is good. at least on the flip4mac plugin.
Bill Hall
September 28, 2011 at 12:32 pmYou can set whatever frame size you want for a wmv using compressor. When you click on your wmv preset(which is a quciktime export component that you set to windows media) it’s under the second menu “encoder”. You can then go to options and set your frame size. You just can’t set the pixel aspect ratio for a custom frame size.
One little glitch I’ve noticed using this though. If you change any parameter and save the stetting you need to go back in an reset your frame size and save again.
Rafael Amador
September 28, 2011 at 1:35 pm[Chris Borjis] “doing it through compressor is not going to help as the resize options are not there like they are when you do an .mov”
you are right.
I haven’t noticed that before.
rafael -
Chris Borjis
September 28, 2011 at 6:01 pmresizing is there yes…but no option for high quality resizing.
take any HD file and make it smaller with flip4mac…it looks horrible.
you have to make an intermediate .mov thats properly downsized first.
