Activity Forums Adobe Premiere Pro Exporting a DV project to tape
  • Exporting a DV project to tape
    Posted by Will Gaffney on July 12, 2006 at 1:17 am
    I posted on this forum a little while ago with this same problem but still have not been able to do anything to fix it.
    Here is the problem:
    I have shot a short movie (D1/DV PAL 16:9 Widescreen (1.422)) using my Sony FX1, edited it using Premiere 2.0, and now I wish to export it back to tape via the fire wire cable.
    The movie was shot and edited in 16:9, but when I export it back to the camera it comes out in 4:3 and the picture is anamorphic (vertically stretched).I have reset all settings on the camera and made very sure that the camera is set to DV and not HDV, which didnt alter the result. So I believe that the issue is Prem Pro related.
    Are there any settings on PP2 that I may be unaware of that I need to adjust so the exported image is in 16:9?
    I have done this before using the same camera, but an older version of Prem Pro and did not have this issue.
    I am now getting desperate, so any response would be greatly appreciated.
    Will Gaffney replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
