Activity › Forums › Adobe After Effects › Exporting a composition from illustrator
Posted by Anthony Thomas on December 21, 2006 at 2:12 amCan I export an composition from illustrator, lets say an assembled motor cycle model, and still have all the pieces maintain their relative position. It seems I have to do a reassembly. Is there a way around this?
TONY T
Anthony Thomas replied 19 years, 8 months ago 3 Members · 7 Replies -
Mylenium
December 21, 2006 at 6:48 amNot that I know of. If it’s an option, simply export your AI as a layered PSD. It will be easier for AE to handle this, anyway (it doesn’t need to rasterize).
Mylenium
[Pour Myl
Tony Kloiber
December 21, 2006 at 3:52 pmMake sure that your saving the AI file as pdf compatible. Place cropping layer at the edges of you AI file.
In AE import file as composition – cropped layers.
Make sure to put anything you want to animate separate from the other objects (on it’s own layer) as everything on a layer is one object in AE.
If your not going to scale the image up you wouldn’t need to set continuously rasterize, if your are then use it.TonyTony
Mylenium
December 21, 2006 at 5:38 pmYes indeed. Clearly goes to show that I’m working to rarely with Illustrator. *g*
Mylenium
[Pour Myl
Anthony Thomas
December 21, 2006 at 8:21 pmHey, we will have to see if it works. So thanks to you too
Tony Kloiber
December 21, 2006 at 9:40 pmI may have describe it incorrectly because it has been a while for me as well but all the layer should come in and remain lined up.
Less mograph more Vfx lately as well as doing a lot of the text right in AE.
TonyTony
