Activity Forums Apple Final Cut Pro Legacy Exporting a 30 minutes seq in less than 10 minutes
  • Exporting a 30 minutes seq in less than 10 minutes
    Posted by Pedro Casais on June 14, 2009 at 3:29 pm
    I got a final 30 minutes seq that I like to quickly put on the ipod for easy viewing on a tv monitor. I noticed fcp doesn’t have ipod export settings but anything close to what it needs to be for ipod takes at least an hour or two. Is there a quick and good enough export setting that might take less than the actual running time of the seq? I got a mackbook pro intel 1gb ram
    Zane Barker replied 17 years, 2 months ago 3 Members · 3 Replies
  • Pedro Casais
    June 14, 2009 at 3:40 pm
    I’m trying to create just a qt reference from my seq, so I go to export-quick time-settings as current and no contained movie selected. Stills take more than the running time of the sequence, is it still writing media even though the contained movie is unchecked? I don’t have anything red or not render in my seq.
    thanks.
  • Rafael Amador
    June 14, 2009 at 4:26 pm
    Pedro,
    Which is your sequence codec?
    If is HDV or XDCAM each cut means to rebuild a GOP.
    To export a Reference Movie you need to have ALL the sequence rendered.
    [pedro casais] “I don’t have anything red or not render in my seq. “
    Are you sure?
    Select All and Option-R to be sure.
    About the compression speed, normally: The faster, the lower quality.
    rafael
    http://www.nagavideo.com
  • Zane Barker
    June 14, 2009 at 9:01 pm
    [pedro casais] “I got a mackbook pro intel 1gb ram”
    First thing get your self more ram.
    [pedro casais] “I got a final 30 minutes seq that I like to quickly put on the ipod for easy viewing on a tv monitor”
    First let me say that playing a video from an iPod is not the best way to show quality of video. However the fastest way to create a file that will play on an iPod, is to export a reference video file from FCP and then use the turbo.264HD from Elgato. The turbo.264HD is a USB hardware encoder that significantly speeds up the time it takes to create h.264 files.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
