Activity › Forums › Apple Final Cut Pro Legacy › exporting a 3 hour show
  • Steve Eisen
    August 13, 2013 at 4:16 am
    Use Compressor. Use a very low bit rate. Around 2.5.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Alexander Kallas
    August 13, 2013 at 12:37 pm
    Why only a single layer? your quality will be way down at that low data rate.
    Go double layer.
    Cheers
    Alexander
  • Kevin Aspinwall
    August 13, 2013 at 2:43 pm
    Steve and Alexander, many thanks for your response. I will try both suggestions. Can our 5 year old DVD burner that came with our Mac Pro handle a Dual layer DVD burn?
  • Alexander Kallas
    August 14, 2013 at 7:37 am
    On your machine, look in About this Mac>System Report>Hardware>Disc burning>DVD Write, that will show you wether it is capable.
    For double layer on the Mac in DVDSP, the DVD+RDL discs work best.
    Cheers
    Alexander
  • Kevin Aspinwall
    August 15, 2013 at 6:36 pm
    Alexander, thanks for the info! I will check it out.
