Activity › Forums › Adobe Premiere Pro › EXPORTING 8 CHANNELS OF AUDIO IN PREMIERE.
  • EXPORTING 8 CHANNELS OF AUDIO IN PREMIERE.
    Posted by Jonathann Launer on March 22, 2024 at 3:49 am
    Hey, everyone.
    I am delivering a movie, and the client wants 6 channels of 5.1 mixes, and 2 channels of stereo mixes on the same file. Every time I go to export, my options only go to 6 channels, even though I have created a new output sequence with 8. Thoughts?
    Eric Santiago replied 2 years, 6 months ago 3 Members · 2 Replies
    March 23, 2024 at 2:02 am
    Hey Jonathann,
    Sorry, but we need more info as to your specs, and what codec you are using, and where the film will be shown.
    My gut feeling is that you need to go DCP. although some codecs do come with 8 channels of audio.
    But first, it is worth checking whether your Channel Mapping is set-up correctly?
    https://helpx.adobe.com/uk/prelude/using/clips-channels-tracks.html
    Do keep in mind that even if you set 8 channels out, if the codec used can only carry 4 audio channels. Then you will only get 4 channels, regardless.
  • Eric Santiago
    March 23, 2024 at 3:25 am
    I’ve had to export eight channel audio using MXF.
    Mads tips should help.
