Activity Forums Apple Final Cut Pro Legacy Exporting 7D from final cut express hd- Bad quality
  • Exporting 7D from final cut express hd- Bad quality
    Posted by Dom Fisher on March 29, 2013 at 12:05 pm
    Hi
    I have 7d footage which I’m trying to export from Final cut express and when I do it loses quality and comes out a little pixelated.
    The video is 1920 x 1080, 25 fps, in ‘Get Info’ it tells me Codecs: H.264, Linear PCM. The total bit rate is 46,000- 47,000.
    In Final Cut the easy set up for the project is HDV-Apple Intermediate Codec 1080i50.
    Then I export it at Compression Type: H.264. Keyframes every 25 fr. Encoding: Best Quality.
    And export Dimensions: 1280×720 HD
    What am I doing wrong?
    Please Help I need to sort this ASAP.
    Dom Fisher replied 13 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    March 29, 2013 at 1:50 pm
    Hi Simon,
    FCE converts all the stuff to AIC, which is a very compressed codec.
    There is not much you can do to improve the quality due to the high compression.
    rafael
  • Dom Fisher
    March 29, 2013 at 2:52 pm
    Hi rafael
    There is a very distinctive loss in quality i’ll upload a clip onto vimeo so you can see. Your suggesting that 7d footage can’t be rendered out just to look normal hd because mine certainly doesn’t look average hd and I’ve exported 5d that looks better quality so there must be something going wrong?
  • Rafael Amador
    March 29, 2013 at 3:09 pm
    Sorry, i thought you were getting bad quality on your AIC master from FCE.
    When making your H264, set alway “Key-frames: AUTO”, so the application will put the optimal number of Key-frames. A key-frame every 25 frames, as you have set, is is very little to keep to keep some quality.
    Select “Multipass’, and set the data rate as high as possible.
    rafael
  • Dom Fisher
    March 29, 2013 at 3:40 pm
    ok i’ll try auto and see if taking bit rate per sec off automatic and putting in a number between 50,000 and 90,000 makes a difference, heres a link to the clip where you can see static fuzzy stuff going on the back of the car and becomes more obvious once graded…..https://vimeo.com/62941777
    Thanks for your help it is very much appreciated!
  • Rafael Amador
    March 29, 2013 at 6:13 pm
    [Simon Hutchins] “d putting in a number between 50,000 and 90,000 makes a difference,”
    That’s a huge data rate.
    Bluray is around 35.000Kbps.
    rafael
  • Paul Esteves
    March 31, 2013 at 3:39 pm
    Is that “static fuzzy” not there in FCE when you edit it? Does FCE not have a function to export current settings? In FCP7 you have the choice to do a quicktime conversion or just export with current settings. I find it best to export current settings and then transcode it from that for whatever purpose I need the video for.
  • Dom Fisher
    April 9, 2013 at 10:49 am
    Hi there I’ve actually moved to premiere pro and just to be certain I’ve set up a project dslr 1050 25 fr and if i export at h.264 and from premiere pro once iv finished my edit, it comes out as an mpeg4, is this right and i’m not 100% certain if it comes out best quality with these settings? Also just to comfirm I don’t need to convert the footage into something before editing in pro?
