Activity › Forums › Apple Final Cut Pro Legacy › Exporting 5.1 Stems form FCP
  • Exporting 5.1 Stems form FCP
    Posted by Nick Meyers on November 4, 2015 at 12:04 am
    i’ve been making some cuts to a film using the existing 5.1 stems, Dialogue, Effects, Music
    i’m going to re-export as a single 5.1 group.
    this will be used in a DCP, and for a screening from Quicktime
    my thinking is to set up 6 mono outputs, all with 0db downmix
    then assign the appropriate tracks to the appropriate outputs.
    i see FCP has a default 5.1 audio output setting, which is NOT set up like this.
    my guess is this is just (as it says) just for monitoring, and my 6 mono output is correct for what i need,
    but i just wanted to check with the expoerts.
    maybe 6 mono for CDP, and FCP’s 5.1 for the Quicktime??
    nick
    Nick Meyers replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
