Activity Forums Adobe Premiere Pro Exporting 4:3 from my 16×9 project
  • Exporting 4:3 from my 16×9 project
    Posted by Ken Hodson on July 20, 2005 at 3:33 am
    I use AspectHD to edit my 720p projects. I decided to put some old 4:3 SD footage I had into the project. Upon export my 16:9 footage was letterboxed as normal, but my SD portion was letterboxed vertical and horizontal. So I adusted the project so I just have the SD footage in the 720p project with the thought that I could export to 4:3. But no matter what options I try I can’t seem to make this happen. Any advice on how to get my 4:3 footage in a 16:9 project back to full screen 4:3 would be appreciated.
    Steven L. gotz replied 21 years, 2 months ago 2 Members · 3 Replies
  • Steven L. gotz
    July 20, 2005 at 4:30 pm
    Reverse the situation. Put the 16:9 letterboxed into a 4:3 SD project.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Ken Hodson
    July 20, 2005 at 4:48 pm
    That is prety much what I have arrived at. I broke up my timeline and rendered out the 4:3 footage, and the 16:9 footage seperately.
    Import the 4:3 footage into a 4:3 SD timeline then zoom out untill it fits. Then add the 16:9 footage then export to 4:3 DVD.
    Best I could come up with.
    Thanks for the help
  • Steven L. gotz
    July 20, 2005 at 6:18 pm
    I just bring the 16:9 footage into a standard 4:3 project and scale it to fit as letterboxed. Add the 4:3 footage and the 16:9 footage together and it works fine as a 4:3 project.
    In order to set up the ability to pan and scan the 16:9, I use a letterbox title over the video to restrict it to the original shape. Although, I often find a lot of HDV footage that works as 4:3 when zoomed in a bit anyway.
    Steven
