Activity › Forums › Apple Final Cut Pro Legacy › Exporting 422 HQ + Alpha channel from After Effects CS5 = quality loss when paste into FCP
  • Exporting 422 HQ + Alpha channel from After Effects CS5 = quality loss when paste into FCP
    Posted by Enguerrand Bouillaguet on October 1, 2011 at 9:28 pm
    First of all I’m french so i apologize for any future grammatical mistakes.
    Now for my editing configuration :
    Mac Pro OS X 10.6.8
    After Effects CS5
    Final Cut Studio 2 suite (FCP Pro 6)
    Here’s the problem… I know it has already been discussed elsewhere but I haven’t find any solution at this point.
    I’m working on some motion graphics in AE that needs to be incorporated into an FCP timeline…
    my FCP timeline have these settings :
    – Apple Pro Res 422 HQ progressive
    my export settings from AE are these :
    – Quicktime Animation codec quality 100 RGB + Alpha
    The output video is fine when played on Quicktime Player but when pasted into FCP the quality loss is visible.
    I have then made a second export from AE with Apple Pro Res 422 HQ codec settings and when paste into FCP timeline, the result is perfect (i mean no quality loss) but the alpa cannel is gone by the way and so i can’t composite it anymore with the underneath video (because of the black background of course)…
    I’m pretty lost now…
    If anyone have already been through this particular workflow i would be glad to know how…
    Here’s my screen capture
    On the upper side of the picture you can see the Animation + Alpha channel
    And on the bottom the Apple Pro Res 422 HQ export
    Felipe Balista replied 13 years ago 6 Members · 20 Replies
  • 20 Replies
  • Rafael Amador
    October 1, 2011 at 10:30 pm
    [Enguerrand Bouillaguet] “I have then made a second export from AE with Apple Pro Res 422 HQ codec settings and when paste into FCP timeline, the result is perfect (i mean no quality loss) but the alpa cannel is gone by the way and so i can’t composite it anymore with the underneath video “
    In FC you can use the picture from the ProresHQ file and the Alpha from the Animation file.
    Set the Prores picture (as Travel Matte Alpha) picture over the Animation.
    rafael
    http://www.nagavideo.com
  • Enguerrand Bouillaguet
    October 1, 2011 at 10:52 pm
    Thanks but it can’t be done this way…
    Because if i use as alpha matte the QT animation as a shape for my nice 422 export well… guess what? I’m getting the pixellated edge of the QT animation… So unfortunately it’s pointless.. 🙁
    But thanks anyway 😉
  • Rafael Amador
    October 1, 2011 at 11:16 pm
    [Enguerrand Bouillaguet] ” I’m getting the pixellated edge of the QT animation.”
    That sounds to a wrong interpretation of the kind of Alpha Channel.
    Are you exporting “Pre-Multiplied” from AE?
    Have you checked the Alpha options in FC?
    rafael
  • John Pale
    October 1, 2011 at 11:17 pm
    You should not be getting that kind of degradation with Animation.
    Are your frame sizes set correctly? Field order (if any) ?
    Anyway..if you can find an upgrade to Studio 3, you can use ProRes 4444, which has support for Alpha Channels and keys in real time in FCP. I would not pay for an upgrade to Studio 3, though, as with the arrival of FCP-X, its a dead product.
    October 1, 2011 at 11:18 pm
    Pre-Multiplied from AE
    Where do you find Alpha options in FCP ?
    October 1, 2011 at 11:21 pm
    frames sized to 1920×1080 progressive in both applications
    October 1, 2011 at 11:25 pm
    The weird thing is that there’s absolutely no trace of image degradation in Quicktime player the quality loss happens only in FCP, so what the hell ???
  • Rafael Amador
    October 2, 2011 at 8:58 am
    [Enguerrand Bouillaguet] “Pre-Multiplied from AE
    Where do you find Alpha options in FCP ?”
    By default FC works with “Strait Alpha”, so if you can export from AE that way, better.
    In FCs Browser > Alpha column, you can change the clip Alpha (Strait/black/white).
    rafael
  • Chris Tompkins
    October 2, 2011 at 5:40 pm
    It should look fine in FCP.
    Are you Fully Rendering?
    View on external monitor?
    Chris Tompkins
    Video Atlanta LLC
    October 2, 2011 at 5:56 pm
    yep fully rendered !
    results equal on two different monitors…
