Activity › Forums › Maxon Cinema 4D › Exporting 3D objects with a transparent background.
  • Exporting 3D objects with a transparent background.
    Posted by Margaux Millet on December 12, 2015 at 3:03 pm
    Hi everyone,
    I created several objects on C4D, I’d like to use (after compositing) on AE. I tried several ways, but the result on AE is not very good… I tried to import the C4D file on AE, but it seems like “not finished”, I mean, it doesn’t look as good as on C4D. We can’t see the reflexions from the mats and so on. I guess I need an alpha channel so I can add a background behind the object afterwards. I did so, and tried to export it in .png file, but:
    -Borders of the object are not that transparent: we can still notice some borders around the object.
    -It seems like the object is not really straight (in both x and y axis), is there a way to turn it completely straight?
    In fact, after exporting on AE, the object, which used to be in high-quality and completely manipulable seems really cheap on AE. Is there a way to export that correctly on AE? So it has the same quality and I can use it in 3D, make it spin and so on?
    I looked for tutorials and tried, but it’s not really the same issues as the ones I’m encountering at the moment.
    Thank you in advance.
    Margaux Millet replied 10 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
