Activity › Forums › Apple Final Cut Pro Legacy › exporting 3840 x 720 project in fcp
  • exporting 3840 x 720 project in fcp
    Posted by Filip Martin on August 24, 2010 at 4:18 pm
    hello
    I’m currently working on a 3840×720 project in fcp,
    the movie is meant to be projected on a very wide screen
    my material consists mainly of video shot on xdcam ex 1080p25,
    but I also need to add several prerendered movs in H264 and Prores
    and some large Tiffs,
    I created an fcp sequence that is custom 3840×720, with compressor settings xdcam ex1080p25,
    I have now a 1min. portion that I want to export for testing on the projection hardware
    ( I was told that playing a 3840×720 mov in H264 at 30Mbps would be OK, and that blending would create a perfect image using 3 projectors)
    my problem however, is that I don’t seem to be able to export this 1 min. 3840×720 sequence,
    neither via “export qt”, nor “export with qt conversion” nor via compressor…
    (the final mov will be something like 12mins.)
    I keep getting error message “out of memory” (in fcp) and ‘failed” (in Compressor)
    Desperate for help!
    my machine is a 2×2.8 GHz Quad-core MacPro, with 16 GB of RAM
    Filip
    Walter Soyka replied 16 years, 1 month ago 2 Members · 1 Reply
  • Walter Soyka
    August 24, 2010 at 4:39 pm
    [Filip Martin] “I’m currently working on a 3840×720 project in fcp,”
    For projects like this, I usually do my offline edit in FCP, but I online in After Effects. FCP has poor support for non-standard resolutions.
    You might have better luck changing your sequence compressor to an intraframe codec like ProRes, Uncompressed, or PhotoJPEG.
    Walter Soyka
