  • Posted by Holly Arnold on July 9, 2010 at 2:03 pm
    When you export a quicktime file from Final Cut Pro does it automatically compress it to h.264 or do you have to do this manually through quicktime conversion?
    Dan Monro replied 16 years ago 2 Members · 1 Reply
  • Dan Monro
    July 9, 2010 at 2:59 pm
    Depends how you export it. If you don’t specifically tell it to convert using quicktime, it will export a same as source QT – whatever your sequence is.
    If you want it to convert to H264, use the “export using quicktime conversion” option, and change the settings in the dialog box.
    Personally, I export a same as source and then let compressor do the conversion using a droplet. That way you keep editing while compressor runs in the background. You can also “share” it with compressor, but I don’t have much experience with that one.
    Cheers.
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.4 GHz Intel Core 2 Duo 2 GB ram
    Mac OS X 10.5.8
    GeForce 8600M GT Final Cut Pro 6.0.6 Quicktime 7.6.4
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.5.8
    NVIDIA Quadro FX 5600 Final Cut Pro 7 Quicktime 7.6.4
