Activity › Forums › Apple Final Cut Pro Legacy › exporting
exporting
Posted by Anastasia Marshall on August 10, 2009 at 1:01 pmHi
Exporting a very short piece on FCP is taking forEVER! For example, a two minute interview at settings H.264, 1920 x 1080 takes about 4 hours to export but they’re the only settings i could find which played back with enough quality and at 16:9 on youtube 🙁
Can anybody help??
Anastasia
David Roth weiss replied 17 years ago 5 Members · 4 Replies -
Nicole Haddock
August 10, 2009 at 3:09 pmYou’re compressing a very huge file to a very small file, so unless you have a big, beefy desktop Mac and/or a Turbo, it’s time for a Render Wander.
It is the way it is.
Nick Meyers
August 10, 2009 at 3:20 pmthat seems like a very long time.
maybe you have LOTS of effects in your timeline?
the best way to do this is to NOT do hte conversion in FCP.
work in your sequence,
render,
export as a Quicktime Movie, same settings.bring that clip into COMPRESSOR,
and do the h264 conversion there,even if it takes a long time,
you can keep working in FCP.nick
John Fishback
August 10, 2009 at 3:27 pmAnd, if you have a multicore machine, Compressor will use them all of them if set up properly.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
David Roth weiss
August 10, 2009 at 3:28 pmHave you rendered your sequence completely and is “Full” checked in the Render All drop menu? The FCP factory default settings do not have that checked, so don’t assume it is, and if it’s not, then you are re-rendering every frame during the export, which will slow things down tremendously.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
