Activity › Forums › Apple Final Cut Pro Legacy › Exporting 16×9 Anamorphic?
  • Exporting 16×9 Anamorphic?
    Posted by Seawild on August 27, 2005 at 6:20 pm
    Good morning, I need help.
    I am trying to export a movie out FCP.
    The footage was captured with DV NTSC Anamorphic Setting.
    And here are my sequence settings.
    720×480 NTSC DV 3:2
    NTSC – CCIR / DV Anamorphic(checked)
    lower field dominance
    29.97
    Compresssor DV/DVCpro – NTSC
    I am trying to make a 16×9 DVD. But, when I export the movie and watch it in Quicktime it is not 16×9!!
    Please I need your help. I am really hung over. I swear I will never drink again… jebesus.
    Chris
    Wilhelm Beck replied 21 years, 1 month ago 3 Members · 3 Replies
  • David Battistella
    August 27, 2005 at 9:29 pm
    Import the movie into DVDSP and then tell dvdsp that the media is 16×9. When you create the DVD it will play back in the correct aspect ratio.
    d
  • Seawild
    August 27, 2005 at 10:32 pm
    PS There is a quicktime update called the anamophizer. Just out on the apple site.
  • Wilhelm Beck
    August 28, 2005 at 10:06 am
    I`ve had the same issue myself.
    When I further exported anamorph from QT Pro through Compressor to another format it showed up just fine!
    I do find it quit unbelievable that Apple hasn
