exporting 16:9 uncompressed 8 bit
hi,
I’ve been unsuccesfully trying to export a 16:9 uncompressed 8- bit file.
I’ve checked the manual, and it says to use Quicktime conversion and change the aspect ratio. The problem is, I cannot change and setting when exporting uncompressed 8-bit. Only when I change the compression for something like DV-PAL I can change the settings. But I need better quality than a simple DVexport.
Is there any way to change the aspect ratio of an uncompressed 8 bit export?
The sequence is set to 16:9, and so are all the vids…
