Activity Forums Avid Media Composer exporting 16:9 to tape?
  • exporting 16:9 to tape?
    Posted by Rob Roams on August 4, 2005 at 4:24 pm
    I have a 16:9 sequence that was built in Avid xpress Pro 4.5, 23.976 NTSC. When I export the sequence to miniDV it converts to a 4:3 ratio. Can you please let me know how i can keep the 16:9 ratio. Would exporting to a High def format be the only way to keep the 16:9 ratio?
    Thank you
    Rob Roams replied 21 years, 1 month ago 2 Members · 2 Replies
  • bouke Bouke
    August 5, 2005 at 3:42 pm
    basics:
    16:9 in SD is squeezed material so it fills the 4:3 frame. It is supposed to be stretched by the monitor.
    If you put it onto a DVD with the correct flag set, 16:9 monitors will automaticly swithch to full frame, 4:3 sets will letterbox (if they are not too old)
    hth
    bouke
  • Rob Roams
    August 5, 2005 at 5:27 pm
    Thank you,
    Are there settings within avid xpress pro to export the 16:9 to 4:3 letterbox, or is that something i need to do with a separate program. I did a qt ref. export to standard 4:3 it looks OK but I rather have the 4:3 with letterbox.
    thanks again.
