Activity Forums Apple Final Cut Pro Legacy Exporting 16:9 still image
  • Exporting 16:9 still image
    Posted by Mumblinjr on March 23, 2007 at 11:18 pm
    Hey gang. I’m trying to export stills from my FCP show. We are working in 720p 24 (16:9). When I export a still it comes out 4:3 – the aspect ratio is always squished. Is there any remedy to this? Also, I don’t have Photoshop on this rig.
    Rafael Amador replied 18 years, 10 months ago 4 Members · 4 Replies
  • David Roth weiss
    March 24, 2007 at 12:02 am
    An anamorphic format will yeild anamorphic stills upon export. Export a small chunck of your video containing the still frame to an 8-bit uncompressed QT at the non-anamorphic full frame size of your video and then export a still from that using QT conversion.
    DRW
  • Rafael Amador
    March 24, 2007 at 4:34 am
    Open your still in Photoshop and go to the IMAGE MENU> Pixels Aspect ratio and choose the one of your original footage. Then Photoshop will display the image properly and not like square pixels.
    Cheers,
    Rafael
  • Julia Barreto
    November 9, 2007 at 3:12 am
    sorry, but as far as I now the pixel aspect in photoshop is for preview only.
    So if this is write the only thing would be do what David said. I confess I didn’t understand but all try that.
    Thanks David.
  • Rafael Amador
    November 11, 2007 at 4:24 am
    Dear Julia:
    Photoshop only works with SQUARE pixels. But allows you to display those pixels in other fashions.
    If you open a PS document with 720×576 you will see an almost square image. But if you display the same doc as Annamorfic, your image will be displayed as 16×9.
    Same document, same picture, same pixels, but just displayed in two differnt ways.
    Rafael
