Activity Forums Adobe Premiere Pro exporting
  • exporting
    Posted by Nazreen Mohamad on December 29, 2010 at 6:24 am
    Correct me if I’m wrong, but the primary method of producing the video is exporting right?
    But , I’m having problems. I have a source MOV footage, the resolutions are 1240×720, but they get sized down to 720×576. I don’t want to lose the quality as I want to use the footage in After Effects alongside other footage that is still 1240×720.
    Nazreen Mohamad replied 15 years, 8 months ago 2 Members · 4 Replies
  • Andrew Devis
    December 29, 2010 at 1:56 pm
    Hi Nazreen
    If you are using the production premium suite I would add the footage to after effects through dynamic link and not export it at all from pp.
    Hope this helps
    Andrew
    … because it’s all about stories …
  • Nazreen Mohamad
    December 29, 2010 at 3:50 pm
    Premium? mine says adobe premium pro cs4. how do i use the dynamic link?
  • Andrew Devis
    December 29, 2010 at 5:00 pm
    Hi Nazreen
    How did you buy pp and AE? If you bought them together in one package you have dynamic link. However, if you bought them as individual programs then you won’t. I did a tutorial on dynamic link from the pp workflow perspective. start by looking at that in the premiere pro tutorial section. It is much the same from AE and should give you an idea how it works.
    Hope this helps
    Andrew
  • Nazreen Mohamad
    December 29, 2010 at 5:21 pm
    I actually don’t know. I use my bro’s laptop. Thanks, i will look up dynamic linking.
