Activity › Forums › Adobe Premiere Pro › Exporting
  • Exporting
    Posted by Justin Zaza on June 30, 2010 at 4:42 pm
    I edited my film with windows movie maker.
    1st question: will that compromise the quality? I exported from movie maker as a DV-AVI file.
    2nd question: Will the quality improve or degrade if I import the DV-AVI file into Premiere and then export it again?
    3rd question: what are the best exporting formats in premiere pro cs3?
    (I want to export to dvd, for film fest submissions, but later on I will need to export in a file type, for it to then be transferred to “HDCAM”
    Vincent Rosati replied 16 years, 3 months ago 2 Members · 1 Reply
  • Vincent Rosati
    June 30, 2010 at 5:15 pm
    1 – Generally regarding image quality, it doesn’t matter what tool you use to edit. DV-AVI is an editing format, but it is compressed so that export does equate to 1-generation of loss.
    2- Importing into another app will not degrade the image. However, exporting into a compressed format will equate to an additional generation of loss. Exporting as Uncompressed will not cause a loss of visual quality, but it will eat up a huge chunk of disk space. There are visually lossless codecs available that will allow for smaller files.
    ‘Improving’ digital footage is a very objective process. It depends on what you mean.
    3- The ‘Best’ export settings are also subjective. Ideally you should export into the format that you will be using for delivery or archive.
    Generally you’ll want to export with 2-Pass VBR with bitrate settings that are the highest that you or your medium are willing to accept.
    It’s a good practice to do some compression/export tests with a small 1-minute clip before encoding a large project, using different bitrate settings.
    I haven’t used a very recent version of Premiere yet, so maybe something has changed, but your project settings should equal the desired encoding format. So if you need two versions, you would have two projects. You would import your ‘final’ project (not he export, but the actual Premiere project file) into this second project.
    Do all of your encodes/exports now, while the project is on your drive, before dumping or archiving your source files, so you don’t have to reload your source files at some later time.
    Just some ideas.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
