Activity Forums Adobe Premiere Pro exported videos lose quality
  • exported videos lose quality
    Posted by Wordplay on May 23, 2006 at 10:04 am
    i’m using adobe premiere 1.5 and when i export my videos the edited scenes as well as scenes i didnt touch and export loose sharpness compared to the actual clips recorded. can anobody explain this?
    i’m exporting as microsoft dv avi.
    Wordplay replied 20 years, 3 months ago 3 Members · 4 Replies
  • Rob Sgarlata
    May 26, 2006 at 9:01 pm
    Sounds like it is a compression issue. You are compressing the file so it loses some quality. I don’t use the microsoft dv codec so I don’t know much about it. Try another codec, like the picvideo lossless codec, or Huffyuv. There are lots of codecs available for different purposes.
  • Wordplay
    May 29, 2006 at 11:05 pm
    thanks alot for replying rob, where do i get the picvideo lossless codec from? and how do i select it?
    n00b in need of help!
  • Thorsten Wolf
    May 30, 2006 at 9:27 am
    you should check the “always compress” checkbox if i remember correctly. You shouldn’t loose sharpness while using microsoft DV avi though… I’ve used it before… it’s a 3 MB/sec standard codec… never had sharpness issues before.
    check if you’re exporting to the same settings (pixels) as your original footage… happened to me once, the resize crippled my exported video…..
    Thorsten
  • Wordplay
    May 30, 2006 at 8:46 pm
    even if i resize them into smaller proportions? that destroys the quality? because i certainly did crop them down quite a bit.
