Activity Forums Adobe Premiere Pro Exported Videos from Multi-Camera Sequence not Identical to the Frame
  • Exported Videos from Multi-Camera Sequence not Identical to the Frame
    Posted by Ramon Galvan on June 14, 2013 at 2:45 pm
    I imported media and made a multi-camera sequence, set the in/out points, exported each camera with identical in/out points. However, the durations differ by a few frames even though I’m conforming to ProRes with same in/out points. Anyone ideas as to why they are not accurate to the frame? This worked out fine in FCP7.
    Ramon Galvan replied 13 years, 2 months ago 2 Members · 3 Replies
  • Kris Merkel
    June 14, 2013 at 3:39 pm
    Are all of your sources same frame rate, resolution, codec ect?
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Ramon Galvan
    June 14, 2013 at 3:53 pm
    Yes. I think I fixed the problem. The display format was not set to 30fps Non-Drop-Frame Timecode.
  • Ramon Galvan
    June 14, 2013 at 5:41 pm
    Never mind. The problem still exists. I changed the sequence to Non-Drop-Frame and the issue still occurs. There are 3 different angles that I put into Multi-Cam. I exported each angle. 2 angles seem to be identical (by the frame), but the third is off by about 3 frames. Any ideas?
