Activity › Forums › Apple Final Cut Pro Legacy › Exported Quicktime file is 7 seconds longer than original?
  • Exported Quicktime file is 7 seconds longer than original?
    Posted by Khashyar Darvich on September 24, 2006 at 3:31 am
    Hi Everyone,
    I exported a project in FCP 5.11 to a self-contained Quicktime file (using Quicktime 7.13), and while the FCP project is 2:00:38:00, the exported Quicktime file plays at 2:00:45.
    When I reimport the QT movie, it again reads that it is 2:00:38:00 when placed in a sequence.
    My sequence is non-dropframe, so I wonder if Quicktime 7.13 is displaying the exported movie in drop frame?
    The only reason why this concerns me at all is because when I import the QT file into DVD Studio Pro, the audio and video are out of sync.
    Thanks for any thoughts that you might have.
    Khashyar
    Rafael Amador replied 20 years ago 2 Members · 4 Replies
  • Khashyar Darvich
    September 24, 2006 at 5:17 am
    I am going to try to export the QT movie with compressor and see if the sync issue goes away.
    Please feel post any thoughts that you may have as to why the exported QT movie is longer than the original FCp sequence.
    Khashyar
  • Rafael Amador
    September 24, 2006 at 10:54 am
    Hi Khashyar,
    I belong to the PAL world, but if I.m not wrong, yours is a problem of Drop Frame and Not DF.
    In DF NTSC, you skeep 18 frames every 1o minutes of film. Your film is 120 minutes. So you will skeep 12 x18 frames= 216 frames. 216 frames is a more or less 7 seconds. That is the time difference that is anoying you.
    Salud,
    Rafael
  • Khashyar Darvich
    September 24, 2006 at 6:45 pm
    thank you very much for your feedback, Rafael.
    I also think that somehow, the updated version of Quicktime (version 7.13), is playing the film in drop frame, even though I exported the film in non drop frame.
    I have exported sucessfully this way several times and it has worked every time except for the past 2 days.
    To solve the issue, I exported a Quicktime file, then used Compressor to export an MPEG-2 video file and a Dolby 2.0 audio file. I then imported those into DVD Studio Pro, and the video and audio were finally in sync.
    I am curious whether others have experienced the same issue with Quicktime 7.13?
    Anyway, I imagine that Compressor produces a higher quality MPEG-2 than DVD Studio Pro (at least I will have more control over the quality of the MPEG-2 conversion).
    Thanks again for your thoughts,
    Khashyar
  • Rafael Amador
    September 25, 2006 at 6:19 am
    Hi Khashyar,
    Yes with Compressor you can controll much more the process. Why are you using AAC audio instead of .aiff?
    Salud,
    Rafael
