Activity › Forums › Blackmagic Design › Exported PAL frames are fieldy
  • Exported PAL frames are fieldy
    Posted by Margus Voll on January 26, 2008 at 8:07 am
    Hi.
    I’m capturing from digibeta filmed material which does not have
    fields originally (transfere from actual film). In FCP it all seems fine but when i export it as frames through QT conversion or through motion i get frames where diagonal lines and edges tend to go blocky. If i export the same material from Premiere material is clean. I use the wery same files captured on FCP. Can it be the problem of FCP?
    I have heard the same problem from a buddy of mine also who edits on FCP. We both have BM Multibridge (one is newer model one is older). Eny ideas?
    Margus
    https://iconstudios.eu
    Simon Blackledge replied 18 years, 8 months ago 3 Members · 2 Replies
  • Del Chapple
    January 30, 2008 at 10:25 pm
    hmmm. DBC is an interlaced format wich by its nature can have different images on f1 than on f2, thats the nature of the beast. i’d guess unless the footage was shot progressively ie HD 1080p25/720p50 and Down converted to PAL the footage may be interlaced, unless its a SloPal transfer but that would be from a NTSC source. In FCP the viewer doesnt show you fields it only shows you frames, but outputs interlaced video. And premire might just be outputting Frames instead of fields..
    del
    you cant hear my inner voice scream… can you..?
  • Simon Blackledge
    January 31, 2008 at 9:08 am
    What are you exporting as? Via QT conversion.
    Better option is to export QT with no conversion and load that into the app your going to.
    s
