Activity Forums Adobe Premiere Pro Exported media is not the same as when viewed in the timeline
  • Exported media is not the same as when viewed in the timeline
    Posted by Mark Asquith on September 15, 2017 at 10:28 am
    hi all
    I have a project, made up of 48fps HD drone and 25fps HD camcorder footage. It’s rendered, with effects and transitions and plays fine in the timeline. I imported the various clips by ‘keeping existing settings’.
    However, I am having 2 problems ( challenges )
    1-When I apply higher speed settings to clips, CS6 is dropping frames from the end of some of them – so I have had to overcompensate to get clips to end where I want them to – but this takes time and effort and I’d rather not have to! (each one has to be rendered to make sure it stops at the right place)
    2-although the finished project plays fine in the timeline, the exported media (mpeg2; I have tried exporting as 25fps pal and 29.97fps ntsc – same result), the final mpeg includes parts of sequences that I have edited out as well as missing smaller pieces that I have left in.
    I can’t find a similar problem elsewhere in the forum. I suspect it’s settings-related but can’t see how or what I am doing wrong. I have always edited only 25fps dvcam footage before and have never had this problem.
    thankyou for any guidance in resolving!
    Todd Perchert replied 8 years, 11 months ago 3 Members · 12 Replies
  • 12 Replies
  • Jon Doughtie
    September 15, 2017 at 3:08 pm
    Is any of your drone footage VFR (variable frame rate)? Premiere Pro needs CFR (constant frame rate) footage.
    You can convert VFR to CFR using Handbrake. It’s free. (handbrake.fr)
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Mark Asquith
    September 15, 2017 at 4:45 pm
    Thanks Jon I’ll check that out , haven’t changed whatever default setting it came with ( other than setting from 4K to hd). Hadn’t considered that at all so Thankyou and hope that’s it! Regards, mark
  • Mark Asquith
    September 15, 2017 at 11:17 pm
    darn … Hi Jon, I converted varios clips to constant by using handbrake, put them into the sequence to replace existing clips … but CS6 still drops frames …… I am ‘gutted’. Looks fine in timeline but exports a different perspective. hugely frustrating….. Am hoping for other suggestions ….
    all the best,
    Mark
  • Mark Asquith
    September 16, 2017 at 12:08 pm
    I’m trying different settings to export with but none yet work – tried h264, mpeg 2, at 25 and 29.97fps. I have keyframe change set to 1, bitrate 8mbps, am rendering at max depth.
  • Mark Asquith
    September 18, 2017 at 11:33 pm
    hi Jon, no change – all is the same – yet the exported h264 file (or mpeg – tried both) is different to what I see when i view the project in the timeline -I don’t get it ….. and it’s very frustrating!!). My footage is sped up; if I don’t , I dont get the problem (but I need to speed it up for this project). help …! regards, Mark
  • Todd Perchert
    September 19, 2017 at 6:37 pm
    Have you tried transcoding your footage to a different file format, like DNxHD or ProRes? Something that PPro may handle a little better. As far as previous edits showing up in render, delete your render files, then try your render again if that happens.
    TC
  • Mark Asquith
    September 19, 2017 at 10:01 pm
    thanks Todd will try that (although Handbrake doesn’t seem to have those outputs – have you a recommended software that would transcode to these formats?). I’ve deleted the previous render files and will re-render. It’s very frustrating; I’ve use Premiere for years and not had this before – it’s only since I’ve been using 48fps (drone) footage. I am using custom project settings of 50fps (as 48fps is not an option).
    I’ll reply again when have re-rendered.
    thankyou for the advice, regards, Mark
  • Mark Asquith
    September 19, 2017 at 11:03 pm
    hi Todd
    re-rendering didnt change things I’m afraid. Have found that handbrake DOES convert to PRO-RES so trying that now
    regards, Mark
  • Todd Perchert
    September 20, 2017 at 3:20 pm
    I thought you may be able to convert to another format with Media Encoder. Would def make files that work well in PPro.
    TC
  • Mark Asquith
    September 21, 2017 at 9:12 am
    Thanks Todd
    Does this mean encoding to a different FPS setting (i.e. from 48 to 60) which Premiere can handle (as I suspect that it’s the frame rate that is causing the problem) or do you think by converting the 48fps footage to a different file type – but still at 48fps – will solve the problem? thankyou!
