Activity Forums Adobe After Effects Exported frame looks different than the comp that rendered it when imported back in. Why?
  • Exported frame looks different than the comp that rendered it when imported back in. Why?
    Posted by Max Bretherton on May 13, 2015 at 1:40 pm
    hi…apologies if this has been answered before. I’ve looked but can’t find an answer.
    I have colour management turned on to sRGB in AE and i’ve exported a frame as psd layers.
    Now when i bring this image back in (as sRGB) and put it back into the comp that rendered it it looks different.
    Why ?
    My monitor is set to sRGB.
    Thanks…MAx
    thanks and my best regards…max
    Head of Post Production
    STUDIO LIDDELL
    Max Bretherton replied 11 years, 3 months ago 2 Members · 4 Replies
  • Walter Soyka
    May 13, 2015 at 2:47 pm
    [max bretherton] “I have colour management turned on to sRGB in AE and i’ve exported a frame as psd layers. Now when i bring this image back in (as sRGB) and put it back into the comp that rendered it it looks different.
    Why ?”
    This is almost certainly not a color management issue.
    From the documentation on rendering and exporting still images [link]:
    “A layered Photoshop file saved from After Effects may look different from the frame viewed in After Effects if the frame uses features that Photoshop doesn’t support.”
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Max Bretherton
    May 13, 2015 at 3:02 pm
    Thanks for your quick response Walter.
    I can’t find anything in my comp that would not be available in Photoshop. There are no effects on the layers except a Curves adjustment layer above everything. And no transfer modes either.
    Its a simple animation of a clients logo and branding.
    So I need the colours to be true.
    Looks ok whilst in AE.
    It’s very odd.
    STUDIO LIDDELL
  • Walter Soyka
    May 13, 2015 at 5:52 pm
    That Curves adjustment layer will not translate. Open up the PSD in Photoshop and see. You’d need to recreate that.
    You can save your Curve from within the Curve effect as an ACV file. In Ps, add a Curves adjustment layer and load the ACV.
    Walter Soyka
  • Max Bretherton
    May 14, 2015 at 10:09 am
    Thanks for that Walter. A penny just dropped for me after reading that. It’s cos it’s a layered PSD export. I get it. I just exported a jpeg and brought it back in and its identical to my comp. Of course the layered PSD export is a different process and yes the difference is the adj layer. Thanks for pointing that out. Lesson learned.
    Best wishes…Max
    STUDIO LIDDELL
