Activity Forums Adobe After Effects exported data from boujou not pasting into AE
  • exported data from boujou not pasting into AE
    Posted by Michael Goldberg on February 15, 2008 at 8:01 pm
    I have tracking information that I’ve exported from boujou, and I want to import that data into the position property of an ae layer. I can’t seem to get it to paste thought. I think it might be not enough info in the header of the text file. Anyone have any ideas on how to get this data into AE?
    BTW, I’ve succesfully imported mochaae data from a text file into AE, but can’t do it with the text file that boujou is exporting.
    Mike
    Jonathan Wiley replied 18 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jan Sherlink
    February 16, 2008 at 12:35 pm
    Install the Boujou.aex filter in you AE Plug-In folder,
    you can download it from the 2d3 website or export as Maya file
    cya,
    Jan
  • Michael Goldberg
    February 16, 2008 at 3:29 pm
    Hi Jan,
    Actually, I’m not trying to import the camera from boujou. In fact the shot we have does not have a successful solve. what I want to do is export 1 individual track, and paste that into the position parameter of a layer in ae. I can export individual tracks from boujou, but it won’t paste the data into ae.
    Mike
  • Jan Sherlink
    February 16, 2008 at 6:01 pm
    I don’t know Boujou that well,
    but Boujou doesn’t track objects, it tracks the camera.
    Even if you get a good solve, elements in your scene won’t have position-data but reference points in your 3D scene.
    So … i think … there’s nothing to paste..
    and again i could be wrong
    cya,
    Jan
  • Michael Goldberg
    February 16, 2008 at 10:22 pm
    Hi Jan,
    Boujou tracks 2d points in your scene. From these scenes, it calculates where it thinks the camera is on each frame. If it can do this, you end up with a good camera solve, and then can import the camera into your 3D or compositing program. You can export the 2D tracks as a text file with X and Y data for each frame. The tracking is much better than AE. I end up with a text file with position data. What I want to do is paste this position data into an AE layer’s position, and it’s not working. Mocha exports a text file that you can paste into AE, and it does work. I thought someone might have run into a similar situation.
    Mike
  • Jan Sherlink
    February 18, 2008 at 9:16 pm
    Now i see it,
    if you copy keyframe data from AE to a textfile and compare it with the boujou-textfile, you can see there’s a difference in text-formatting.
    If you’re lucky, some whiz at aenhancers.com might write an import script…
    Since I’m a complete noob at scripts I didn’t succeed in writing it myself 🙁 strange that it doesn’t exists already
    cya,
    Jan
  • Michael Goldberg
    February 18, 2008 at 9:56 pm
    Hi Jan,
    I found this document on adobe’s web site, and this helped identify where the problems were in the exported text file. Essentially I opened the text file in Excel, created a new column, cleaned up a few stray numbers, and deleted the name of the track. Once I did this, everything lined up correctly, and it imported correctly into AE. The boujou track is so much better than AE built in tracker, and worked like a gem for this particular purpose.
    Mike
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/help.html?content=WS98BCDDB7-89CB-49cb-B94D-6CEB6CED4462.html
  • Jonathan Wiley
    March 11, 2008 at 11:19 am
    Hey Mike,
    I was struggling with the same issue recently. It caused me to check out SynthEyes as an alternative, which ended up giving me a properly formated .txt file for the paste. Here’s how it was formated:
    Adobe After Effects 6.5 Keyframe Data
    Units Per Second 30
    Source Width 1920
    Source Height 1080
    Source Pixel Aspect Ratio 1
    Comp Pixel Aspect Ratio 1
    Position
    Frame X pixels Y pixels Z pixels
    0 1145.59 454.86 0
    1 1145.39 454.18 0
    2 1145.35 454.59 0
    I’ll still continue using boujou as it works best with Cinema 4D, but I have to admit I was very impressed with SynthEyes as an (much less expensive) alternative and will probably purchase a copy sometime in the future to replace my AE tracker as AE’s tracker is just about worthless to me.
    – Jon
