Activity › Forums › Apple Final Cut Pro Legacy › Exported AVIs: How to get to a PC?
  • Exported AVIs: How to get to a PC?
    Posted by Matt Larson on September 23, 2009 at 2:20 pm
    I’ve got 50GB of AVI files from FCP that I need to send to someone editing with a PC. I’ve got an external hard drive ordered that I am planning to use to ship the media, but I’m trying to figure out how to format the external USB drive so the files that I add from the Mac can be used on the PC.
    I tried the MS-DOS FAT 32 format in Disk Utility, but that couldn’t be read by my PC. Is there any format that will allow an external drive to be accessed by both a Mac and PC? If the new hard drive arrives formatted to NTFS, will that work?
    My back up option is to transfer the files to a PC via File Sharing and then add to the external, but I’m hoping to not transfer 50GB over my network. Suggestions?
    Thanks.
    Matt Larson replied 17 years ago 3 Members · 4 Replies
  • Rafael Amador
    September 23, 2009 at 3:17 pm
    [Matt Larson] “I tried the MS-DOS FAT 32 format “
    Don’t try FAT-32. They have a limit of 4Gbs files.
    [Matt Larson] ” Is there any format that will allow an external drive to be accessed by both a Mac and PC?”
    Only FAT-32. But you can’t use it.
    [Matt Larson] ” If the new hard drive arrives formatted to NTFS, will that work? “
    You will need an application (Paragon NFST) to manage it from your Mac.
    You can also format your HD for Mac. The PC will need “MacDrive” to control the HD.
    rafael
    http://www.nagavideo.com
  • Matt Larson
    September 23, 2009 at 3:19 pm
    I knew there was a 4GB limit in there somewhere, so I exported all the clips to be about 3.5GB.
    Looks like FAT-32 should work then?
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
  • Bouke Vahl
    September 23, 2009 at 4:41 pm
    Yes, it will work, but there can be other issues.
    50 Gig is not that much. A half decent gigabit network is faster than your average el-cheapo transport drive, so that will not make a difference in time.
    (I edit on gig-ethernet, although with iSCSI)
    You should be able to get about 20 – 30 MB speed.
    So it should take you less than an hour over your network.
    (Of course Rafaels solutions are great, but if it’s a one timer, be done with it the easy and safe way..)
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Matt Larson
    September 23, 2009 at 4:52 pm
    [Bouke Vahl] “but if it’s a one timer, be done with it the easy and safe way.”
    Excellent advice. I’ll transfer to the PC first, thanks!
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    G-Speed XL 12 RAID
