Activity Forums Apple Final Cut Pro Legacy Exported Audio is shorter duration when brought back into FCP
  • Exported Audio is shorter duration when brought back into FCP
    Posted by Mark Mathews on February 20, 2013 at 9:08 am
    Hi there, I am really at a loss and desperate for some help.
    I have done this once before and it worked fine, but for some reason something is not working. I am setting up six tracks of audio, 2 stereo panned left and right, 2 music and effects left and right and 2 dialogue. When I did this before I mixed the sound as I wanted in FCP and then exported the tracks as I needed them, as AIFF’s.
    I then brought the AIFF’s back into FCP, lined them up with the footage and all was good.
    However, I have gone to do the same again and when I bring the audio back in the audio track is less in duration?
    So, on my timeline the in and out points tell me the clip is 22minutes.
    I export it as an AIFF and QT tells me the clip is 22minutes
    When I bring it into FCP it tells me it is 21:58:15 and no longer matches my footage?
    What is going on?!! All the footage has 48khz audio. I export it as 48Khz and I have checked the in and out points a million times.
    I have so much to do and yet can’t get any further with this issue. Please, can someone help?!
    Nick Meyers replied 13 years, 6 months ago 2 Members · 5 Replies
  • Nick Meyers
    February 20, 2013 at 8:07 pm
    double check your sequence pre-set
    if the frame rate does not match your working sequence, you can have sync issues importing audio.
    nick
  • Mark Mathews
    February 20, 2013 at 8:11 pm
    Hey Nick,
    Yep, my sequences are 25fps and my footage is the same…?
  • Nick Meyers
    February 20, 2013 at 8:24 pm
    in your A/V settings, do you have a 25fps sequence checked as the pre-set?
    nick
  • Mark Mathews
    February 20, 2013 at 8:42 pm
    In the Audio/Video settings I have HDV 1080i50 preset, which is 25fps…
  • Nick Meyers
    February 20, 2013 at 9:41 pm
    sorry, then i am at a bit of a loss, too.
    a clarification:
    are you exports cut short, or are they playing out of sync?
    if cut short, try adding some slug to the end of the track and re-export.
    do you need AIFFs?
    can you export as quicktime movie, current settings. audio only?
    have you tried copying your timeline into a new sequence and trying the export from there?
    nick
