Activity › Forums › Adobe Premiere Pro › Export/Burn DVD from 24p 1920×1080 DSLR footage (CS 5.5.2)
  • Export/Burn DVD from 24p 1920×1080 DSLR footage (CS 5.5.2)
    Posted by Alex Grene on January 25, 2013 at 4:18 am
    Hello all,
    I have been editing a feature film on Premiere Pro CS 5.5.2; it was shot on the Canon 5D Mark II, and saved as a series of 1920 x 1080 .MOV files (audio recorded separately as 48kHz WAV files on a Zoom H4N, subbed in to replace crappy camera audio). I would like to make DVDs of the film for submission to various places. The film is 1 hour 48 minutes (108 min.) in length from tip to tail. I have Adobe Media Encoder 5.5.2 as well as Premiere; what are the best export settings for me to use? (I have Kodak dual-layer DVD-R+ 8.5GB DVDs, but can easily pick up another type if these are not compatible with your average DVD player.)
    System stats:
    -Intel Core 2 Quad CPU Q9300 2.5 GHz
    -8GB RAM
    -Windows 7 Ultimate 64-bit OS
    -Optiarc DVD RW AD-7260S
    -NVIDIA GeForce 9500GT GPU
    -1TB built-in storage, 3TB external (Seagate 3TB Backup Plus USB 3.0)
    PS: Apologies if I’m providing redundant/ inadequate information here; I’m new to this business, and am not sure what is/ isn’t standard practice…
    Best,
    Alex
    Angelo Lorenzo replied 13 years, 8 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    January 25, 2013 at 4:54 am
    There should be a preset for that in Adobe Media Encoder and in Premiere. Choose MPEG2-DVD as the format and pick NTSC 23.976 Widescreen High Quality in the preset list. Then adjust the bitrate settings according to the media you’ll be burning it to. You can see the estimated file size under the Use Frame Blending tickbox.
  • Angelo Lorenzo
    January 25, 2013 at 5:12 am
    Tero is correct, but I would do the following if you want some extra quality:
    General quality (first slider): 5 (max)
    Bitrate encoding: vbr 2 pass
    Min bitrate can be set to 4
    Target can be set to 6
    Max can be left at 7
    Although you can set the max to 9, you need to leave headroom for audio. DVD, as standard format, has bitrate restrictions.
    https://en.wikipedia.org/wiki/DVD-Video#Data_rate
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
