Activity Forums Adobe Premiere Pro Export XML from Premiere to FCP7
  • Export XML from Premiere to FCP7
    Posted by Aaron Barton on February 8, 2012 at 5:31 pm
    Hey guys,
    I’m trying to get a workflow that will allow me to send edits to and from Premiere and FCP7 using ProRes files.
    When I sent and XML from FCP to Premiere, it looks like everything worked fine. Some of the Speed changes were slightly off, but nothing serious.
    On the other hand, when I sent an XML from Premiere to FCP7, the edit comes in fine, but I get the red render line at the top. The sequence and the footage are at the same setting, but for some reason it’s still requiring me to render the timeline. I even tried removing all the speed changes and effects from my edit so that it was only cuts and it’s still having problems. Is there something I’m missing when making my XML from Premiere?
    Aaron
    Chad Wilson replied 14 years, 7 months ago 2 Members · 1 Reply
  • Chad Wilson
    February 8, 2012 at 6:47 pm
    I have had to relink footage when coming from FCP TO PrP. You might try that. That might relocate the xml metadata information attached to the original footage.
    Best of luck,
    Chad
    “Every child is an artist. The problem is how to remain an artist when you grow up.”
    – Pablo Picasso
