Activity › Forums › Adobe Premiere Pro › Export XML for Final Cut But is blank when imported
Posted by Toby Heslop on November 8, 2010 at 9:22 pmI have a Premier Pro CS5 Project and media that my client brought to me. I opened the project and exported an XML so I could move this project over to Final Cut Pro 7.0.3.
Whne I do so the XML opens in Final Cut after a very long time and the is just blank in the FCP browser.Is there something I’m doing wrong. I thought this software was could do this cross over?
OSX 10.6.4, CS5, PP 5.0.2, FCP 7.0.3
Toby Heslop replied 15 years, 9 months ago 2 Members · 3 Replies -
Todd Kopriva
November 9, 2010 at 5:04 amWhen you save a Final Cut Pro XML file from Premiere Pro, it creates a log file. Check out that file. What does it tell you? See this page.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Toby Heslop
November 9, 2010 at 6:07 amSee below,
I read this as
– Titles were replaced by Slugs in FCP
– Add disolve was replaced with Cross Dissolve
– Gamma correction didn’t come through
– 3 way CC didn’t come through
– Filters didn’t come throughMy problem is that the XML hasn’t even transformed the media in FCP, as the FCP project is blank!
Translation issue:
Synthetic Item (Title 09) not translated, Slug used as a placeholder.
Translation issue:
Synthetic Item (Title 10) not translated, Slug used as a placeholder.
Translation issue:
Synthetic Item (Title 11) not translated, Slug used as a placeholder.
Translation issue:
Synthetic Item (Title 13) not translated, Slug used as a placeholder.
Translation issue:
Synthetic Item (Title 14) not translated, Slug used as a placeholder.
Translation issue:
Sequence at 00:00:01:01, video track 1: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:00:05:16, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:07:18, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:09:23, video track 1: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:00:14:09, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:19:12, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:00:21:19, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:00:24:01, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:00:30:09, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:34:05, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:35:15, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:00:36:13, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:37:19, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:40:03, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:41:01, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:42:23, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:00:44:22, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:00:47:08, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:00:51:24, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:01:09:04, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:01:23:08, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:01:30:03, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:01:37:08, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:01:51:04, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:02:01:10, video track 1: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:02:03:11, video track 1: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:02:08:21, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:02:09:19, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:02:10:15, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:02:10:21, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:02:11:01, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:02:11:17, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:02:14:09, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:02:15:20, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Translation issue:
Translation issue:
Sequence at 00:02:38:17, video track 2: Effect on Clip not translated.
Translation issue:
Sequence at 00:02:40:11, video track 2: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:03:33:19, video track 2: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:03:35:14, video track 2: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:03:36:14, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:03:38:16, video track 1: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:03:38:23, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:03:42:00, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:03:44:07, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:03:46:22, video track 2: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:03:48:18, video track 2: Transition not translated, Cross Dissolve used instead.
Translation issue:
Sequence at 00:03:57:15, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:03:59:13, video track 1: Effect on Clip not translated.
Translation issue:
Translation issue:
Sequence at 00:04:03:02, video track 1: Effect on Clip not translated.
Translation issue:
Sequence at 00:04:03:02, video track 1: Effect on Clip not translated. -
Toby Heslop
November 9, 2010 at 6:56 amSo I went through the premier Project and deleted all the Transitions and filters and also the titles.
Then I deleted all the cache files and .xmp files, so all that was left was the Original Rushes files, Stills and music & the project file on the scratch disk.
Then I exported and XML for FCP, this time there was no translation file which must mean that there was no problems.
Opened the XML with FCP and still the progress bar hangs at 30% and freezes FCP from working!
Media rushes are ProRes LT 1080/25P
