Activity Forums Adobe Premiere Pro Export XDCam 422 codec with a .mov extension on PC
  • Export XDCam 422 codec with a .mov extension on PC
    Posted by Tony Brecknock on January 21, 2015 at 6:25 pm
    The subject says it all, I am running Ppro CC and need to export to XDCAM 50 with a MOV extension. My understanding is this is Mac only? Is this true, if it can’t be done in Ppro is there third party software somewhere?
    Tony
    Tony Brecknock replied 11 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    January 21, 2015 at 7:32 pm
    We know what you want to do, but can you tell us why? Honestly, other the fact that someone who doesn’t really know much about codecs had requested it, I can’t think of a good reason to create a deliverable as XDCam.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Tero Ahlfors
    January 21, 2015 at 7:46 pm
    [David Roth Weiss] “We know what you want to do, but can you tell us why?”
    That is an actual spec that some channels require. For realsies. Lately it’s mostly XDCAM422 in an mxf container instead of a mov. And yeah you’ll need a mac for that or play around with this: https://code.google.com/p/ffmbc/
  • Tony Brecknock
    January 21, 2015 at 8:15 pm
    That is exactly right David, and thanks I will try your link!
    Tony
  • Shane Ross
    January 21, 2015 at 8:44 pm
    Yeah…XDCAM 422 50Mbit as an MXF is very common as a deliverable. As a QT movie is not…thus the curious nature of the question.
    Shane
    Little Frog Post
  • Kevin Monahan
    January 21, 2015 at 9:54 pm
    Hi Tony,
    This is the 2nd time I’ve seen this in a week. Check out: https://www.calibratedsoftware.com/Products/MXFImportV3/MXFImport.php
    “Calibrated{Q} MXF Import also comes with a ‘helper’ application called Calibrated{Q} Import Assist. This application enables you to batch create QuickTime Reference or Self-contained .MOV files from MXF files, and rewrap XDCAM, XAVC 50/100/200 and AVC-Intra 50/100/200 MOV files back to OP1a MXF Files.”
    I hope that will work for you.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Tero Ahlfors
    January 22, 2015 at 5:22 am
    [Shane Ross] “Yeah…XDCAM 422 50Mbit as an MXF is very common as a deliverable. As a QT movie is not…thus the curious nature of the question.”
    I’ve sent letterboxed 4:3 TGA sequences to channels last year. My time is spent better actually doing those instead of trying to argue the specs the channels have.
  • Tony Brecknock
    January 29, 2015 at 8:19 pm
    ok I have downloaded the file and extracted it but I don’t see how to install it, how do I make it work? any ideas?
    Tony
