export woes
Good Morning-
I’m on a deadline, and having a problem I’ve not had before:
I’m exporting quicktimes, anywhere from 1 minute to 10 minutes (six in all) for use in DVD studio pro. I’ve rendered everything, and I’ve religiously used that pesky mixdown command.
When I burn the dvd, I’ll get a a 2-3 second freeze, then the program continues. I also occasionally get an audio spike in a random place.
I’ve exported self contained quicktimes and non sel contained quicktimes. They both have the freeze issue.
I’ve exported using compressor, and while the quicktimes run well in dvdsp, they’re darker! I’ve never had that happen before. They look like someone raised the blacks on every clip.
I’ve searched both this forum and the dvdsp forum, but can’t find any solution other than the mixdown comand. Am I missing something obvious? Could this be a hard drive problem?
Thanks very much.
Final Cut 4.5, G5 1.8 dual, 3 gigs RAM, GRAID 320 gig hard drive
