Activity Forums Adobe Premiere Pro Export with Media Encoder for Encore
  • Export with Media Encoder for Encore
    Posted by Hans Mansson on July 31, 2010 at 9:38 am
    Hello
    I would like to know which export settings I should use in Premieres Media Encoder (MPEG2, MPEG DVD etc) so that the film is ready to import and burn direct in Encore. I don’t want to any encoding in Encore.
    I know that I can export direct to Encore but the encoder in Encore doesn’t give me the opportunity to use VBR coding etc like in Premiere.
    Many thanks in advance
    Hans
    Hans Mansson replied 16 years, 1 month ago 3 Members · 3 Replies
  • Ann Bens
    July 31, 2010 at 12:42 pm
    The encoder for Encore is exactly the same as for Premiere, which is AME.
    You can change the settings in Encore: File/Edit Quality Presets.
  • Angelo Lorenzo
    August 3, 2010 at 2:18 am
    Use Adobe Media Encoder and use some of the presets listed under Mpeg2 – DVD
    This will spit out a separate video and audio file that you can drag onto the Encore timeline without cross conversion.
    Irregardless, you can tweak settings for encoding, they should ideally fit into DVD video specs. More reading https://en.wikipedia.org/wiki/Dvd_video
  • Hans Mansson
    August 3, 2010 at 9:21 pm
    Thank you both Ann and Angelo for your help!
    Regards
    Hans
