Activity › Forums › Apple Final Cut Pro Legacy › Export with Markers???
  • Export with Markers???
    Posted by David Roth weiss on August 8, 2007 at 9:03 pm
    I exported a timeline with markers at every cut point. Those markers show up in the QT player when the exported file is played back, but when that same QT file is loaded into FCP the markers are not useable. Is there a way to enable them in FCP?
    TIA,
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
    Jeremy Garchow replied 19 years, 1 month ago 2 Members · 14 Replies
  • 14 Replies
  • Jeremy Garchow
    August 8, 2007 at 9:45 pm
    WHen you exported the markers, what kind did you choose?
  • David Roth weiss
    August 8, 2007 at 10:01 pm
    When exporting I chose “all types” — when I put them in initailly I just hit “M” and never did anythng else. Is that right?
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    August 8, 2007 at 10:18 pm
    That is perplexing.
    What are you trying to do? Maybe there’s another way around it.
    Jeremy
  • David Roth weiss
    August 8, 2007 at 10:25 pm
    I had to export a single file froma timeline with many cuts for a client, and want them to be able to find the cut points my jumping to the next marker.
    I’m going back and making each marker a chapter marker to see if that helps… Its real pain though.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    August 8, 2007 at 10:30 pm
    Save your time, it doesn’t work.
    Start a new project, import the orig. clip. Drag the clip into the viewer, mark it up there, then send the FCP project with the one clip as media.
    Jeremy
  • Jeremy Garchow
    August 8, 2007 at 10:32 pm
    Or if you don’t want to make a new project, mark up that one clip in the viewer and then media manage that one clip using the copy function.
  • David Roth weiss
    August 8, 2007 at 10:40 pm
    [JeremyG] “Save your time, it doesn’t work.”
    Correct!!!
    The problem is, they have an earlier version of FCP.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    August 8, 2007 at 10:42 pm
    What are the different versions?
    Fcs2 to their fcs1?
    I’d bet an xml would work.
  • David Roth weiss
    August 8, 2007 at 10:47 pm
    [JeremyG] “I’d bet an xml would work.”
    Its from my FCP 6 to their FCP HD 4.5. Think it would work?
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    August 8, 2007 at 10:56 pm
    I bet, if you did an XML v1
    Jeremy
