Bring it into AE, do whatever you need to do with it, add it to the render queue. Then click on the text next to thw words “output module.” Change the format to any type of image sequence such as Tiff of Targa. Just make sure under channels it says “RGB + Alpha.” Also, depth has to say something like “Millions of colors +” or “Trillions of Colors +.” The plus sign indicates that an alpha channel can be exported. Also, keep in mind that you can add extra output modules to do things like exporting the RBG channels separate form the alpha.
~Colin
