Activity Forums Apple Final Cut Pro Legacy Export with alpha to Animation codec-wrong frame rate?
  • Export with alpha to Animation codec-wrong frame rate?
    Posted by Tom Matthies on July 31, 2015 at 1:42 pm
    Looks like this problem has been around for a while but I still haven’t been able to find the answer.
    I have a short “Snipe” assembled in FCP7. I want to export it as an Animation file with alpha to run on air. When I export from the FCP7 timeline (1920×1080 59.94fps) the resulting file Animation codec file runs at about 6 frames per second. It seems to play normally in Quicktime player, but will run at 6fps when loaded into the on-air playback system. The inro tab in Quicktime player also shows an incorrect frame rate. This problem appears to have been known for a while. Is there a solution to get the resulting Animation file to be the correct frame rate?
    Not my monkeys. Not my circus.
    Tom Matthies replied 11 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    July 31, 2015 at 3:51 pm
    The animation codec is an old and inefficient codec requires lots of throughput for seamless playback, are you simply dropping frames during playback because your hard drives don’t have the necessary throughout?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Shane Ross
    July 31, 2015 at 5:01 pm
    Also…1080 59.94fps? I hope you mean 1080i59.94…29.97fps. 1080 60fps…ANIMATION…is a HUGE data rate to try to play back. And of course on air is only 29.97.
    I’m sure you knew that…but the 59.94 is confusing unless you say 1080i59.94
    Shane
    Little Frog Post
  • Tom Matthies
    July 31, 2015 at 5:03 pm
    I can’t use ProRes 4444. The device that plays the Snipes back on the air requires either an Animation/alpha file or a numbered Targa or PNG sequence. It takes the file or the image folder and renders it out to it’s propitiatory file format for playback. The numbered TGA method works but it’s understandably a much larger file to deal with and they are having problems positioning it correctly on the screen (OP Error?). The animation file plays in the correct position but it’s playing back about 4 times faster than real time. It’s supposed to be a 10 second snipe. I exported it out of Motion instead and it seems to work OK. Wouldn’t Motion utilize the same Quicktime conversion engine as FCP7?
    Weird…
  • Tom Matthies
    July 31, 2015 at 9:00 pm
    59.94 fields per second. I always thought that was just wrong to lost as a frame rate. Actually 29.94 in real life.
  • Tom Matthies
    July 31, 2015 at 9:03 pm
    List not lost…darn auto correct…
  • Nick Meyers
    August 1, 2015 at 6:33 am
    i’ve had weird frames rates from exports in the past,
    a solution has been to open the files in Cinema Tools and conform them to the correct frame rate.
    nick
  • Tom Matthies
    August 3, 2015 at 10:07 pm
    Excellent idea! I’ll give it a try.
