Activity Forums Apple Final Cut Pro Legacy export weirdness
  • export weirdness
    Posted by Craig Lindvahl on November 11, 2005 at 5:17 pm
    Hi-
    I have a corporate project due Monday, and I’m experiencing something quite odd.
    The project is about 09:30. When I export (I’ve tried both a self contained quicktime and the regular quicktime)everything is fine, except that two voiceover audio clips from the beginning of the project don’t come through in DVDSP. The music bed is there (directly underneath the voicover), as is the video.
    If I open the quicktime in Final Cut or in Quicktime, the audio is fine. It’s only in DVDSP that the first :45 or so of the on voiceover track doesn’t appear.
    Other voiceovers from the same audio clips come through the process just fine, as do all of the other audio and video tracks. The only odd thing I can find is that when I right click on the offending audio clip, it says it is 24fps. In the bin, it tells me the clip is 29.97, just like everything else.
    Am I doing something wrong on the export or the rendering? All of the other audio tracks are fine.
    Aggravating.
    Thanks for you ideas
    Craig Lindvahl
    Michael Peele replied 20 years, 10 months ago 2 Members · 1 Reply
  • Michael Peele
    November 11, 2005 at 8:29 pm
    It sounds like you may want to force a re-render of the audio before you export.
    Delete your audio render files. Another option that may work is to make a change to the audio that is dropping out, then change back (not undo).
    After you have done one of the above, render with all audio render options turned on.
    I have had this issue when I have made nests that included audio that were subsequently edited. Not everytime, actually only twice, but re-rendering the audio seemed to fix the issue.
    Good luck,
    Mike Peele
